First start up....
  • Thread starter Thread starter 65fastbackresto
  • Start date Start date Sep 20, 2007
65fastbackresto
1,229
AR
Sep 20, 2007
  • Sep 20, 2007
I had some conflicting stories, so we started it first at 0 degrees and it was backfiring and running rough. Pulled the dist, set the crank mark at 10, and it ran better, but the motor got up to temp, backfired and quit. The ignition key wont turn the motor over any more, but I can crank it by crossing the solineoid but it still wont start. It does have fire cause I checked but it still wont start, any help here?
blown65
1,938
Queen Creek Arizona
Sep 20, 2007
  • Sep 20, 2007
what kind of ignition?
I know MSD stuff hates low voltage. 10 should run unless you have some crazy cam in there.
65fastbackresto
1,229
AR
Sep 20, 2007
  • Sep 20, 2007
Its MSD, I called MSD tech support today
It wouldn`t start and the guy told me to run the power remote wire directly to the battery because he figured it was getting low voltage at the switch. That worked for maybe 10 to 15 minutes run time on the motor, then this.
If the ignition switch went out, and I can still crank it by the silonoid, is there some way it could cause it not to start still? I kinda thought I went around it by running the wire directly to the battery.....
D
D.Hearne
11,730
south louisiana
Sep 20, 2007
  • Sep 20, 2007
Gotta love old wiring. Check your ground wiring. That's the first thing I'd suspect.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
