Going to change the thermostat tommorrow, I don't think it's working properly. Ended up getting a Stant Super-Stat from local auto parts store and also picked up a waterneck gasket.
My question is, how should I go about this. Do I have to drain the radiator? From what I can tell I just take off the upper radiator hose from the water neck, unscrew the water neck. Clean off the waterneck, take out the thermostat and replace it with a new one. Put a fresh gasket on the waterneck tighten it down and reattach the upper radiator hose. That sound about right or am I missing something? Also, this thermostat doesn't appear to have a hole in it, i keep reading about this.
Anyone want to elaborate on the installing of the thermostat issue so I don't **** something up.
Appreciate it fellas.
The bottom bolt can be tough to get to and the little hose to the water pump can cause you fits, along with the T-stat falling out of place when trying to install everything. But be patatient and you will get it. The major thing is the T-stat slipping out of place when installing the water neck. You will know it happened when you refil it with H20, it will leak on the bottom of the water neck.You don't have to drain all the antifreeze/water, I usaaly drain about 1/4 or 1/2.
