First time to the track. Need some pointers please
fiveoho
1,958
TN
i have never been but have wanted to go. here soon, i plan on going to a nearby 1/8th mile track. i need some pointers on what to do. i will be keeping my car exactly the way it is for weekend driving when i go to the track. 35lb tire pressure, street tires, etc.
im not expecting good times just some experience and hopefully some fun. my reaction time and 60' im sure will be terrible.
heres a few q's i can think of off hand:
since i will be running on street tires, burnout or no burnout? im thinking no
what should i launch at ( i dont want to kill my car )?
what should i shift at?
given my mods in my sig, you guys wanna take a guess at what my car is -capable- of? granted the driver will hurt the times
Don't go through the water box
I don't do a burn out on street tires cept drag radials
Listen to the track workers
Pre-stage and let the other guy pre-stage then stage.
Don't get emo over bad time slips if you're in a big group.
Go around the water, and spin the tires over real quick to clean them off. Dont smoke them.
And slip the clutch when launching. When you feel yourself going back in your seat, start letting off. It takes alot of practise. And be prepared to grip better than you do on the street. they spray sticky **** on the track.
good advice
im not totally sure if they VHT the track on test n tune nights or not. when i went up there a few weeks ago to watch, i never seen them spray or clean the track
Yea, as the others have said, go around the water, just light up the tires to clean the junk off (we're talkin less than a second here), stage the car, and be patient....if your going for a good reaction time, then be hot on the lights, but if your going for a good 60', launch when your ready because the timer doesnt start til you break the staging beams. Obviously dont sit there all day, but take your time. I found that with my old 245/45/17 street tires on my tri-bars, i had good luck with a 2200 launch rpm. I cut a best of 1.99 on those crappy ass tires, so its possible. Just take your time, and have fun, thats the main thing. Drag racing is certainly addicting, and after the first pass down the track, your never gonna wanna leave the place. Be safe, and post time when you get back! Good luck:nice:
I dont see why they wouldnt, its a test and tune, you should keep the track the same on a test n tune and a cpmpetition.
And alot of the bigger cars there NEED the VHT stuff.
good info! i appreciate the tips. not sure exactly when im going to go but i will hopefully make it within a few weeks. will definetly post when i go....even tho it will be embarrassing lol
2200 rpm would be ideal. that way i wouldnt feel like im hurting my car. 1.99 on junk tires is pretty darn good :nice:
Good tracks will know the cars running, and know when to RE-spray the starting line. All tracks in this area that I know of, prep the track before everyone gets there. :wink:
Work on your launches, but also your shift points. 1/8th mile won't get you many shifts, but you can adjust some. BTW - 1/8th mile is a let down. 1/4 is twice as fun. :rlaugh:
What I do to cut good lights is count them as they start going off....1 one thousand, 2 one thousand, 3 one thousand, GO. It'll take some practice, but it works for me. My best light is a .504 and aren't usually any slower than .515 or so. It takes some time to get used to how long it takes the car to actually start moving from the moment you start letting up on the clutch and all that.
I wouldn't worry about cutting a good light though first time out. It's more of a time to get used to launching the car good and shifting and just learning how things work at the track.
ok my first time was a learning experience my leg was shaking so bad i almost couldnt keep the clutch down lol but its a great time
first: no water
second: i found launching around 1800 to 2000 was right about where i wanted to be on my street tires i tried 2400 and spun so i dropped it to 1800 and got a good leave....
and reacting to the lights are a good thing to learn...after you pre-stage and stage then the ambers will start dropping and as soon as you see that 3rd amber light..light up punch it...the time it takes to react makes you leave almost perfectly.
most importantly have fun its what its all about dont get upset because your running slow or you red light or anything just go and learn and have a great time
i see how the counting method could work but i'd say that takes some trail and error
first: no water
leave on last light to compensate for driver reaction delay....makes sense. cool :nice:
