Just took of the upper and the bolts on the stock VC. When I went to put on the fox VC, I noticed the bolts did NOT reach all the way into the block. When I held the stocker next to the Fox, I noticed the wall on the fox is much thicker, and the bolt goes about 1/4" more through the stock one, allowing it to catch on the block.
For anyone who swapped out, did this happen? Do you just need to get longer bolts, or did you "make it work" ?
Those bolts are impossible to find ( you know the one with the first 1/8" tapered and the built on washer at the top)
Thanks
RC
Thanks
RC
