  • 1994 - 1995 Specific Tech
fixable or not?
  • Thread starter Thread starter ISUrb33
  • Start date Start date Jan 8, 2009
First Prev 2 of 2
amplifier28
222
#21
  • Jan 28, 2009
  • #21
bad inertia switch? does the switch cut off fuel supply?
Venom351R
4,548
41
98
MAINE
Jan 28, 2009
#22
  • Jan 28, 2009
  • #22
Yes, its in the trunk near the drivers side brake light under the padding. Big Red button on top of it.
99FiveOh
2,051
20
99
J-Ville, FL
Jan 28, 2009
#23
  • Jan 28, 2009
  • #23
Just need to know if it's fuel or spark related when it's acting up, then it'll narrow it down dramatically!
95Vert383AOD
1,133
34
69
New Bedford, MA
Feb 9, 2009
#24
  • Feb 9, 2009
  • #24
Not sure if this has been mentioned.....but i had this exact issue on a 1988 lincoln mark vii and my 1995 mustang......its usually the ignition module every time. On the 94/95 cars the module isnt on the distributor....its on the front of the passenger side shock tower. remove the intake to access it. They look like the 87-93 unit but are different....and theres a difference between the module for autos and manuals....get an after market performance one.
HISSIN50
34
129
Feb 10, 2009
#25
  • Feb 10, 2009
  • #25
Good idea here.
A couple of little clarifications. When he says intake, that means inlet (as opposed to the air plenum or intake).
Auto vs manual TFI's doesnt apply to 94-95's, and it's an incorrect listing at many parts stores for aero foxes. Ford used Push-start and CCD TFI's. They were generational, not particular to a trans type (namely, CCD limits dwell to allow the coil last longer).
99FiveOh
2,051
20
99
J-Ville, FL
Feb 10, 2009
#26
  • Feb 10, 2009
  • #26
I do know that I converted a 93 GT to 5 speed and never changed the TFI module, didn't know I needed to! It ran fine for years...
parrish5o
Dirty South
Feb 10, 2009
#27
  • Feb 10, 2009
  • #27
Hell I see the problem, you took it to Firestone.
M
miller92063
253
Nebraska
Feb 10, 2009
#28
  • Feb 10, 2009
  • #28
I am having similar problems and at my wits end. I'm about to burn it to the ground. Hasn't started in about 3 months. Turns and turns and turns, but wont start. Pulled the chip thinking it was fouled, that wasn't the problem. My fuel pressure goes up when the key1 is turned, but almost immediatley drops back to zero. I'm sure this is do to an open injector, but it was fine this way for at least six months before all the other problems began.
95Vert383AOD
1,133
34
69
New Bedford, MA
Feb 12, 2009
#29
  • Feb 12, 2009
  • #29
HISSIN50 said:
Good idea here.
^^I stand corrected^^
...But yeah ive had that issue before. I have had the module go on the highway at 70mph.....then magically as i was slowing down the car started running again. Then again ive been stranded randomly for an hour or 2 then magically the car starts again. Either way last spring i took the mustang out....came home and then went to leave 15 min after it was running and it wouldn't start. Fast forward 1 hour and Vrooom. But its not good not knowing when your car isn't going to run. (Especially on the highway)
maypo59
194
Central Kentucky
Feb 13, 2009
#30
  • Feb 13, 2009
  • #30
I didn't see it mentioned, but may have missed it.. Have you ruled out the PIP sensor in the dizzy?? I had a random not start issue that went on for a while, tried several things.. read about the pip sensor problems.. rebuilt dizzy from AZ fixed it, never has happened again in 3 years and 15k miles.
Labora
1,855
26
69
Dallas, Texas
Feb 13, 2009
#31
  • Feb 13, 2009
  • #31
I had a similar problem last year, cost me around 9 months of my car not being reliable/running.
Went to 4 different shops including a ford dealership, none of them could figure it out. The car had a laundry list of parts thrown at it with no effect.
I ended up taking the car to a VERY good ford tech who worked on these cars when they where NEW. He took a lot of time to properly diagnose what was going on and was able to fix the problem. My suggestion is to find a Ford tech that knows his stuff, electrical gremlins are the absolute worst!
Mine ended up being a issue with a crappy rebuilt distributor, coil was also getting some kind of backfeed thru the wires and burning them up (I have a msd coil that melted into goo), and it was eating ignition control modules for lunch. (Also getting hot and burning up.)
First Prev 2 of 2
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 5, 2025
