gearheadboy
It probably HAD quad shocks and someone removed them. The brake drums were impossible to get off because the parking brake was essentially ON from improper adjustment. First off when you replace the shoes that you destroyed getting the drum off, make sure the park brake handle is down completely and the star wheel adjuster in the drum is adjusted completely IN before trying to force the drum on. If it won't go on because it seems the brakes are too far out (applied) then stop. I believe what jrichker was referring to was the adjustment at the inside pull handle.
