I was telling people how I put on my new 75mm maf,and my stang ran like crap!Couldnt understand it,then Mike Keirstead told me to twist it so the sensor is turned away about 45 degrees.Thats it!! I figured what the hell, I got nothin to loose.So I took the bracket off and turned it tords the motor.And BINGO!! I couldnt believe it,something so simple would make my stang run like a raped ape!!! I recomend this method to any one having problems with there MAF !!!!
...anyways...I think Pro-M want to know if you got one simple because what the CAI does essentially is create turbulance when the air enters the intake...Not sure if that would cause your problem or if tilting it would fix it...but just thought you should know...If you call Pro-M talk to either Damian or Sean...the rest of the guys there don't have a clue...
