Just got the rack, shaft, and tie rod ends in today, so i installed everything.
Install went real easy, only took 30 mins or so, and surprisingly everything fit and slipped right on.
I eyeballed the toe in/out,but will leave the final adjustment up to an alignment shop.
Must say, it really cleaned up the look, and even steers really easy with the car sitting still. Should be much easier to steer then my power rack was( without a pump) They say you drop 30lbs, but the diference in a power rack to manual is more like 7-10lbs. They must refer to dropping all the PS equipment, such as pump,lines, and rack.
