They work great if you live in a hot climate. A flex fan will move tons of air at low speeds and hold up better in a performance application than the plastic ones do. Plus, no wiring BS that would accompany an electric unit.
Drawbacks are few, but worth noting:
-A flex fan does not use a clutch and will work at its full capacity irregardless of engine temp. This can lead to slow engine warm-ups if you live in a colder climate.
-Ever have the plastic blade nick you when you were adjusting the timing with the engine running? Didn't hurt to much. The flex fan will slice yor skin/flesh quite nicely, so you have to be more careful working on the motor when it's running, even w/ a shroud in place.
-Flex fans are a little noisy, but most of us don't care about that.
Make sure to use an 18" reverse rotation blade (IIRC Flex-a-Lite 1518) and the spacer you'll need should be Flex-A-Lite #14456.
