Flex a lite Performance fan! HELP
MustangOwner
Banned
Dec 13, 2006
160
Does anybody have the Flex a lite Performance fan? It just replaces your stock fan. Mines all cracked so im gonna replace it so i just thought i'd ask about this fan. I know you need a Fan spacer you gotta buy extra. But does anybody have a any issues with them? Are they any good? Does it effect anything else? Thanks
They work great if you live in a hot climate. A flex fan will move tons of air at low speeds and hold up better in a performance application than the plastic ones do. Plus, no wiring BS that would accompany an electric unit.
Drawbacks are few, but worth noting:
-A flex fan does not use a clutch and will work at its full capacity irregardless of engine temp. This can lead to slow engine warm-ups if you live in a colder climate.
-Ever have the plastic blade nick you when you were adjusting the timing with the engine running? Didn't hurt to much. The flex fan will slice yor skin/flesh quite nicely, so you have to be more careful working on the motor when it's running, even w/ a shroud in place.
-Flex fans are a little noisy, but most of us don't care about that.
Make sure to use an 18" reverse rotation blade (IIRC Flex-a-Lite 1518) and the spacer you'll need should be Flex-A-Lite #14456.
I'm not big on flex fans but do use a FAL metal replacement fan blade (with a thermal clutch). It works very well here in the desert (it is loud though).
Good luck.
