So were at that point to redo the brakes with a disc conv. I just so happen to work in a shop that has the ability to make flexible brake/ high pressure lines (off the clock), but nobody here knows much about brake lines.
So my question to anyone is can you use flexible brake lines from the porportioning valve to the wheels for the front instead of hard line then flex line once you get to the tire?
Thanks.
Thanks.
