How do you get the flywheel bolts off? Everytime I try to break them loose the flywheel moves. Should I just have someone hold it or can I prop something against it?
cobradvm said:I wedge a piece of wood between the crankshaft pulley and the belt - it has a 45* bevel on the end - then wedge it the opposite way when you are putting the bolts back on.
Howard
AJBlackGT said:Go to the parts store and buy the $20 tool that holds the flywheel for you. Its like a spring loaded handle type thing, kinda like an oil filter wrench and it grabs the teeth. This way you won't break anything trying to get to to stay still.
I've done it a few times and never had a problem - its only wood - it ain't that tough that it will stretch or damage a belt - save the $20 for beer money!5spd GT said:Am I reading this correctly...but would that not put unneccesary strain on the belt...and lead to stretching or tearing of the belt?
giddyup306 said:1/2" IR Titanium impact.
5.0 Nostalgia said:If I can find something with a thin enough edge (like a long flatheadscrewdriver) can I prop that between the teeth of the flywheel? I don't care if I break the flywheel because I am probably going to change it (rear main seal made a mess). I don't want to break anything else though. I found those flywheel holders on ebay. Trouble is all of them look different. I want to have one by the time I put it back in because I don't want to break the new flywheel.
