FMS Aluminum Drive Shaft
stangla2
90
Is anyone having problems w. the FMS alu. driveshaft hitting on your lowered SN 95 rides, If so how did you fix the problem
My stang is lowered 1.7 in front and 1.5 in back
Thanks in advance for your help
Yup....Mine hit, and has hit somemore... :nonono:
last thing i did was to install a adjustable pinion snubber, as it was suggested to help...and i haven't seen it get worse....i think it stopped it....been to the drags since i installed it, and haven't noticed it worse....i only have bout and inch of travel and it hits the rear, kinda limits the travel more..
supposedly they help with launching the car to...gotta admit, makes 60' times improved bigtime....
i never did grind the E bracket, that would be the easiet thing to try....mine still has shavings in it... :rolleyes:
For some, its the scurge of the Alum DS....secially when you got 3 or 4 in the car and bang some gears.... :bang: thats when i got the BIG gouge...
Thanks for the info on the LCA, I have about a 100k on the original ones, Does any one have any ideas on which are the best LCA for the buck?
94 GT Vert
AFR 165
306 CHP short blk
and a ***** load of bolt ons
