FMU or AFPR?
  • Thread starter Thread starter Funwith89LX
  • Start date Start date Feb 26, 2008
F
Funwith89LX
  • Feb 26, 2008
I'm getting my fuel system ready for power adder, but now i'm a little confused about FMU. At first i want to use the stock injectors, until i can afford maybe TwEECer or PMS. I found rail mount BBK, Aeromotive and Mallory adjustable fuel pressure regulators that have boost/vac rise ratio 1:1. So those will rise fuel pressure with boost, but is it enough, or is there still need for a FMU when using one of those AFPRs?
fiveohwblow
Official Member
2,169
145
155
Feb 26, 2008
  • Feb 26, 2008
An FMU will run ratios such as 8:1 or 6:1 thus generating much more fuel pressure than 1:1. Anyone will recommend an AFPR with larger injectors. An FMU is just a band aid really for someone who does not have money for a tune, larger injectors etc...
As for the brand, I would recommend Accufab.
Hope this helps!
millhouse
1,985
Simpsonville, SC
Feb 27, 2008
  • Feb 27, 2008
What kind of power adder…and what is your combo?
The stock fuel pressure regulator has a 1:1 ratio from the factory, so unless you have some existing issues with it….there is no need to pick up an adjustable unit yet. If you feel the urge to buy one regardless….I've had good luck with my Kirban.
I'd also strongly advise against getting a FMU. It sounds like you would be taking a shot in the dark with picking the proper ratio….and with no way for you to measure AFR's, you are asking for trouble.
PUNISHER RACING
1,124
FORD CITY, PA.
Feb 27, 2008
  • Feb 27, 2008
If you are running your stock 19's I hate to say it but use the FMU, ideally you should ditch it and run 30's with a 190/255 and an AFPR
F
Funwith89LX
  • Feb 27, 2008
I have Eaton M90. Car is basically stock, just ported e7 heads and BBK shortys + o/r h-pipe. Stock injectors, 255lph intank. It's true budget build, as i don't have much money to spend on it. I will get TwEECer or somethin, but not now. I was thinking to swich to bigger injectors at that point. I know what everybody thinks about FMU, that is why i asked if i could do without it.
I didn't know that stock FPR adds fuel pressure with boost. I thought that it was only those i mentioned that did, because on Summit store theres nothing said about boost on other regulators.
So FMU is a must with my setup? 1:1 ratio is not enough? I am going to run probably less than 6 psi now, depending on what size pulleys i find.
BYRDPE
1,556
Memphis,Tn.
Feb 27, 2008
  • Feb 27, 2008
AFPR are not boost sensitive. Meaning they do not increase fuel pressure under boost.
OTOH...an FMU will.
Silvers
51
  • Feb 27, 2008
What is so bad about an FMU? It seems like it gives you the best of both worlds to me. Are they unreliable or something?
millhouse
1,985
Simpsonville, SC
Feb 27, 2008
  • Feb 27, 2008
OTOH...an FMU will.
Most actually are. They have a 1:1 rising rate which means for every lb of boost the AFPR diaphragm sees, the fuel pressure will go up 1psi accordingly. FMU's on the other hand have a higher ratio than 1:1.
They push your injectors far…far past maximum duty cycle which cause irregular spray patterns or worse, damage or failure. The tend to be somewhat reliable for a while….but I would not trust what they'll do to the rest of the system for long term use. They are not to be substituted for a good tune either. Simply throwing on an FMU does not mean your entire WOT AFR's are going to be safe. What you will typically see is some areas that are lean…and others that are very fat. The only way to get everything in between to come out right is with a tune….in which case you might as well just upgrade the injectors and MAF.
BYRDPE
1,556
Memphis,Tn.
Feb 27, 2008
  • Feb 27, 2008
Thanks for clearing this up for me.
millhouse
1,985
Simpsonville, SC
Feb 28, 2008
#10
  • Feb 28, 2008
  • #10
No problem.
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
  • dan50
  • Jul 18, 2026
dan50
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
