FOCK ME (motor)
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
ite stangnet, lately ive been noticing that me car has been making popcorn on the decel.. didnt do that a couple of weeks ago.. i put new bassani's on it and still the same thing, well today i check the plugs (spray) and low and behold no# 6 looks like its hit some coolant, 7 is completely black with white on top, like it went rich and then immediately lean. 8 looks alright..
car will smoke a little on wot, but the smoke kind of lingers right in that spot and then dissolves.. if i spray it its fine no smoke, it has a kind of weird skip at idle, and on acceleration it kinda feels like a miss, not really smooth like it was..
is it possible to blow out a MLS head gasket? i mean i think it would take alot..
but the popping through the exhaust makes me think of a burnt valve.. idk, im gonna pull the motor tomorrow after work prolly and investigate..
That sucks man.
Check your oil for coolant and your coolant for oil.
Other than that, maybe you just burnt up a plug and it was causing the rough running you're experiencing. Possibly it did lean out, but beat the plug up first... at least that'd be ideal.
What color is the smoke? White would indicate coolant, blue oil, and black fuel.
And you're spraying a 100 wet shot right?
yeah 100 wet shot, its more of a white color, none of the injectors are stuck, they all click. it hasnt been burning excessive amounts of oil either, the oil prolly needs to be changed, but it dosent smell like gas and is not thinned out.. no noticeable coolant loss either..
and i did change that plug out today, went out and leaned on the gas a bit and then made one 2nd gear spray, and it came back black with white on the tip, the thing is its like one side is darker, one side is almost white, its weird, it almost has to be a valve problem, because you can see the direction of the burnt gasses are going on the electrode... its really weird!!
ill get a pic of it here in a couple hours.. gotta get the camera charged.. oh well perfect time to slap on the ole C heads lol
well i was very wrong, i did a compression test and it came up 130psi stone cold, no oil added which is still a lil low, but the plug was fouled as well, so im gonna swap in some fresh oil friday and go easy on it..
there was oil residue on the plug unburnt, so its either a very leaky valve seal, or the rings, has just a hair of blow by, and i mean i can barely even feel it..
Well that's better news.
I agree 130 is a little low, but generally that'll improve a little on a warm motor so I wouldn't sweat it too, too much.
Did you just do that one cylinder? I'd do the rest as well and see how the plugs are looking.
So was the plug fowled with oil or carbon? It doesn't sound like it's too lean.
yep went and got it yesterday, and also i stripped down the car ready to yank the motor and trans, so it will be soon, it should be running by late tonight, or tomorrow sometime..
yeah i think the spray and all that compression, plus the alum block, this thing will haul serious ass!!
