I have the stock GT foglamps on my 98 GT, and one of them has some dirt inside the fixture, so i need to find out how to remove the actual Fixture part so i can clean inside it. Thanks!
Jack up the side you need to remove and remove the 3 small bolts on the back of the metal housing that holds the light and the light will come out in the metal housing as one unit. Once it is out you can remove the light with a torx screwdriver to clean or replace.
