Fog Light Assembly Replacement
My drivers side fog light assembly is broken and I'm just wondering if anyone has had to replace theirs. I'm talking about the entire thing, mounting bracket underneath and all. I have a new one from 5.0 Resto and was just wondering how difficult the replacement is.
Thanks!
Bobby
I replaced mine (just the lens and housing, not the entire bracket) myself last summer with some clear ones. The hole thing comes out real easily. I did it in 20 minutes.
EDIT: I hope you're not a vert. If so, you're gonna need to take out the 25lb weight in the passenger side fender behind the foglight to get to it. Luckily, I had already taken mine out when I did my foglights.
Doing entire assy is pretty tit....If I remember its (3) 12 or 13mm bolts that hold the bracket/light assy in place along with a tab that locates in the bumper...just unplug and remove the 3 bolts....I'd shoot the mothers with some PB blaster first...the bolts screw into those clip nut jobbies...don't wanna bust em...theres plenty of play to re-align the light in the center of the hole before you reef em down..
