Ok i just bought a 95 mustang gt last weekend. The guy put on a cobra front bumper with foglights but they do not work. So i took the center console apart to find out that the switch was not even hooked up. My problem is that there is a gray connector for the foglights i assume. It has 8 wires. It will not plug into the switch. Is there a adapter that i am missing and if so anyone know where to get it (dealership??? radioshack???) and what the part number is or what it is called exactly. Or is the switch wrong?? It looks right compared to what i see in other pics i have found online The connector has round "plugs" and the switch has 4 spade terminals. Any one know which colored wire goes to each spade terminal on the switch. Also i found another thing under there (no it is not the convt harness. It is a white piece of plastic with a metal "plunger" and a wire hooked to it and there is a screw in the plastic that has a black ground wire to it. If i push the plunger there is power at the the other wire. Any idea what it is or what it is for??
OK guys i just found a decent pic and it looks like i need an adapter to do from the connector to the switch right? Where can i get it at? Or is there a way to bypass it from the one end of the connector to the switch using spade terminals or something?
