Well....as some of you may know I'm running a megasquirt as a standalone ecu to control both fuel and spark. I had the lower part of my VE table to the point where my afr was safe and reasonable. Today I decided to hook up the twins and start tuning my boosted portion of the VE table. Now...the boosted portion of my VE table is super rich...so I'm basically tuning it down to get closer to my desired AFR.
While doing some spirited freeway runs in boost....my engine suddenly started making a LOUD metallic ticking noise. At first I thought perhaps I blew out the copper rtv gasket, but not likely as it's a very thin layer. I was unable to check where exactly the noise is coming from as I stalled it when I was backing into my garage.
I could tell however it was coming from the driverside...and it increased with rpms and I do believe it changed pitch. My temperature increased after this noise started occuring...although it didn't go past ~ 215*F.
If you have any idea of things I should check once it cools back down (besides the exhaust) let me know.
