i'll make a few psi with about 3/4 throttle. maybe 4 max. accelerating at lower throttles usually put me right at 0 boost and vacuum. cruising i'm seeing like 20psi vacuum.
what happens when your crusing in 3rd or 4th gear at say 3000 rpm and floor it? do you see more boost, do the tires break loose?
lol Like SaleenGT said, if I'm crusing going 65-75 in 5th (damn you and your tranny Saleen...) and floor it, i'll see 1-2psi which is just enough to pass the granny in the middle lane.![]()
you gotta love that .50 overdrive ratio! i run 80mph and barely turn over 2000 rpm even with my 3.90 gears
you can have the same trans for about $3800 plus clutch and pressure plate.
14psi ain't enough?there is no way the smaller kb will make the boost i need, and the bigger kb is too much money.
