For all those "forged vs. hyper" thread makers
Funny but i bet every person in here bashing me for bashing hypers is RUNNING them right? You guys need to lighten up some. I did say that this doesn't mean every one is going to break, i'm just backing up MY opinion for choosing forged over hypers. I'm not stupid guys...i know there's a billion things that have to do with the reasons for a piston to fail, but there's also a good lesson to learn from history, and that being that every major motorsport out there uses forged or billet pistons, and no matter who's having good luck with hypers, you can't tell me there isn't a reason for that.
Like i said before...does John Force run hypers in his top fuel car? If so i'll shut up..
jrichker said:
Two pistons failing in the same place is evidence of a maufactring defect. I would be sending the pistons back to the place I bought them from and asking for a refund or a new set of pistons from a different manufacturer.
Exactly what I was going to post. Looks like the valve relife was too close to the edge.
89white50 said:
i have yet to see one story or vid of a 505hp z06 spitting "pieces" out the tailpipe of a NA application. please show me to these videos...
Here ya go, posted a couple weeks ago. I don't think this one is stock and the tune was probably off, but still the piston/s let go and you can see bits of glowing metal fly out the exhaust. I guess one could argue that it could have been something else coming out the exhaust but i can't imagine what.
http://www.spdkilz.org/Video-Audio/Corvette/C6Z06Boom.wmv
The problem is, it's tough to validate your opinion based on one example. As others have stated, it's quite possible the rings were installed improperly as well as many other possible reasons for failure.
It's also well known that stock hyper pistons are more than capable of handling more h/p than the stock 5.0 block. http://www.turbomustangs.com/techarticles/stockblock.php
Right...i'm not saying this one example means i'm right and that all hypers are junk, but nobody can tell me they're stronger than forged...they just aren't! They may be great for NA motors and i'm not denying that, i'm just saying that they have less chance of surviving a bad tune or detonation, and they're more limited in your options as far as power adders. This one example was backed up with the fact that he now has to spend more money on more pistons...and since a lot of people go hyper to save money, then buying 2 sets of pistons is NOT saving money in the long run.
Stock
pistons
rods
crank
bolts
All of it.
I don't think you'll that anyone said that. Like with just about everything else, there are trade-offs. Cost is just one factor. There are other properties that differ between th etwo pieces other than just strength or cost. The most desirable of the properties for each type of piston will vary depending on the build and goals.
I don't think anyone is trying to come down on you for the point you're trying to make. Rather, it's that folks are trying to post another point. That point is that there is a cost/benefit that has to be considered for the properties inhearant in each type of piston. Saying that everyone would be better off using forged pistons because they are the strongest available would be a grossly oversimplified statement. Were I going to build an N/A stroker from a stock block or even a mildly boosted application then I might run hyper pistons because they are able to seal better/tighter and might also save me few thousandths on an overbore.
As it turned out, my last build was put together with boost in mind and lots of it. Of course I went with a good set of forged pistons because strength in my case, is a very high priority.
I guess i just have a more narrowed or more uncompromising view on things. I can't stand limitations so the power adder issue would be #1 reason i wouldn't buy hypers. Aside from that, just the fact that they have been known to break....for whatever reasons....i would just save my money and hold out for better parts.
Geez guys i didn't mean to offend anyone! People get too defensive sometimes though.
Oh btw, he found a 3rd piston broke lol.
68torinogt said:
hhaha STFU LMAO
My friend was doing the fuse testing and he is an idiot so he was only probing one side of the fuse with the meter... dumbass and he just got lucky and happened to test the input side of the fuse, I put my stock HU back in and it still didn't work so I knew something had to be up. I rechecked all the fuses and low and behold the power constant fuse was blown...
Id buy hypers for an NA motor and forged for a boosted motor... Needless to say I run stock crap now and will continue to as long as Im limited in funds, but dont plan on holding back the power because of it. Blowing up 5 stock bottem ends (so long as I dont toast the heads in the process) is cheaper than one set of pistons, as we have a bunch of them laying around, :D!
88, i wish you would send me some forged pistons for my build. i would gladly run the two in my NA set-up (obviously at seperate times) and will guarantee the hypers make more power. Obviously each has thier highs and lows, the educated ones realize this. Plus, i got my KB's for less than half of what a forged set would have cost.
Dude the only one getting defensive here is you. No one here has said that hypers are stronger. You are saying that they are worthless, everyone else is saying that although they aren't as strong, they certainly aren't worthless and have been proven to work well in performance applications.
Yes you can say that Stock Hypers are more Capable than the Stock Block, BUT, if something goes wrong elsewhere in the engine for instance dropping a valve, you are more than likely going to have the Hyper Shatter into a Million pieces and take out the entire engine rather than just knocking a hole through the Piston.
Yes, there is no denying that forged pistons are more durable than hypers. Dropped valves however are not common…and quite often can be traced back to improper installation (wrong valve, wrong springs, improper seat pressure etc.). Now…improper piston to valve clearance can also cause unfavorable results with hyper pistons as well.
With that said however….I ask the question….is it justified to spend all that extra dough on the internals of an engine which will self destruct at the same h/p levels as stock?
I myself think that if your installing them just to make your engine "safer" with a bad tune, then you have issues.
Anyways….I'll just continue on abusing the stock block I have with hyper pistons until it splits down the middle. :nice:
Hyperutectic are cast with a higher silicon content and are more brittle than forged, they dont expand or contract as much so tighter tolerances can be had so there will be less blow by or oil consumption.
