  • 1994 - 1995 Specific Tech
? for the 5.0 gods.....
  • Thread starter Thread starter harrisonfiveo
  • Start date Start date Jun 15, 2006
H
harrisonfiveo
  • Jun 15, 2006
Ok...Have a 95GT with GT40p heads, e303 cam, 1.7 rr, trickflow street heat intake. Recently the oil pump took a crap locked up the engine. No problem. Had the engine rebuilt( looking to sell car anyway). Anyways car wont idle in gear AT ALL. Had the problem before engine rebuild, car has an aode with shift kit keep in mind. Replaced IAC valve.. no change. Stock computer in it. Yall think its in the computer, is the cam pullin too much vacuum???
Need help guys.......
F
fordtech28
312
Riverside Cali.
Jun 15, 2006
  • Jun 15, 2006
you probably have a big vacumm leak somewhere ?also check your fuel pressure and timing
94-302-vert
1,947
NE CT
Jun 16, 2006
  • Jun 16, 2006
I would vote that you need to get the computer tuned for the heads and intake, if you haven't already.
That is of cource once you check things like looking for a vacuum leak, upping the idle, etc.
AznStanger3v
2,026
Northern VA
Jun 16, 2006
  • Jun 16, 2006
i think tuning the computer is a last resort. e cams dont pull insane vacuum. big vacuum leaks are a huge problem. check between the upper and lower, then start hitting up things around it.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
