- Oct 14, 2003
- 411
- 0
- 0
Which system is Louder and/or Better? On the FORCE II, do you still need to weld the Stainless Steel tips on? I heard that you did on the older 5.0 systems?
As for the other end of the car, I want to try about a 70MM Accufab Throttle Body. With the 70MM, can I/should I upgrade the fuel injectors? What are the factory (2002GT) injectors rated at...and which ones would you replace them with? Also, will the "factory" computer program work okay with those mods? I heard that the "Superchip" program won't work. Also, what kind of HP increase can I expect from the improved Exhaust, Throttle Body and Injector upgrade?
Thanks for any advice...
