I replaced the head unit and amp in my 1999 Mustang with aftermarket units and now i'm trying to put those factory components in my 1992 Bronco. I don't have all the plugs so i've run into some problems as you'll see...
My bronco has 2 rectangular plugs, one has the 5 wires dealing with power one has the 8 speaker wires going directly to the speakers.
I have the mustang head unit wired in as the power plug from the bronco plugged directly into my mustang's. This leaves 2 more plug holes in the head unit. I plugged in the speaker relay plug(the one with 8 wires - 2 rows of 4) into the head unit and then into the amp. This leaves the plug of 6 which i don't know what is used for on the head unit. I'm assuming it's not necesary.
The amp now has the 8 speaker wire plug going in, and
nothing more.
I need to know the locations and functions of the pins on the amp. There is a connector with 14 pins, 6 on the top and then 8 on the bottom. The top of the connector has 3 pins, followed by a gap, then 3 more pins.
III III
IIIIIIII
There is also 6 pin connector which i don't think needs to be used.
If there is anything more i need to know please tell me.
Any and all help is appreciated! Thank you!
nothing more.
III III
IIIIIIII
