Ford Racing Pedal Install / Removal
What a fun time! I found the best way to remove the dead pedal was to get a small flat scredriver in between the pedal and metal plate. Then gently push up high and low. Then gently push the new one in place. To remove the brake and clutch just pull forward. To Install I put a dab of dish shop on finger and ran on the inside of the under pedal. Then start from the top and work your fingers under the lip and pull the pedal towards the floor board. I removed the gas pedal by using an adjustable wrench. Position it in between the metal grove in the pedal bar(if that makes sense) and the gently push on the pin. Next gently move the existing pedal to the side and push some more. You should now be able to pull the pin out. To install I used a bolt and a nut with a nylon insert to secure. I would not recommend trying to insert the old pin to much of a pain in the ASS. I hope this helps someone. Please and any tricks you may have found for others to see.
Mike in AZ
What a fun time! I found the best way to remove the dead pedal was to get a small flat scredriver in between the pedal and metal plate. Then gently push up high and low. Then gently push the new one in place. To remove the brake and clutch just pull forward. To Install I put a dab of dish shop on finger and ran on the inside of the under pedal. Then start from the top and work your fingers under the lip and pull the pedal towards the floor board. I removed the gas pedal by using an adjustable wrench. Position it in between the metal grove in the pedal bar(if that makes sense) and the gently push on the pin. Next gently move the existing pedal to the side and push some more. You should now be able to pull the pin out. To install I used a bolt and a nut with a nylon insert to secure. I would not recommend trying to insert the old pin to much of a pain in the ASS. I hope this helps someone. Please and any tricks you may have found for others to see.Mike in AZ
