- Oct 20, 2003
- 27
- 1
- 0
I'm about to start building a forged longblock from the ground up for plans of putting on a Kenne Bell 2.2 Supercharger on later next summer. Just had a couple questions on some of the engine components. I was wondering what the best type of piston would you go for the Kenne Bell, dished, flat or domed and what cc and bore. Currently I was thinking about (ModMax 220-25200-20 CP 17cc Power Dished 3.572"(+.020) 2618 Alloy Pistons). Also as far as cylinder heads I was looking at a set of the SHM 4.6L 2V P.I. Full Race Heads with the following specs (Intake flows 225 cfm, 0.600” lift, Exhaust flows 205 cfm, 0.600” lift, 47cc chamber volume) paired with some Comp Cams XE270AH Hot Street PI Modular Xtreme Energy Cams. Any other suggestions for heads? Thanks.
Check out the Lightning, Cobra and Ford GT. All these are positive displacement blown and all are running an 8.5:1 compression for longevity.
