Ok I heard guys on here using 4 banger springs up front..Do you also use 4 banger springs out back and how much dose this lower the car..I did a search and didnt have much luck..
you use 4 cyl springs in the front, and v8 in the back. that's a budget drag suspension that lowers your car quite a bit. don't have exact specs, but I believe its lower than csprings.
when someone installs 4 cyl springs on the front of their car it's for weight transfer, not for lowering. a lower stance is just an added bonus. actual drop in ride height i'm not too sure of
the stock springs or fox body gt springs are usually used out back
