FOX ALTERNATOR UPGRADE. WHICH ONE? HELP PLEASE. NEED ONE ASAP.
  • Thread starter Thread starter biglg
  • Start date Start date May 1, 2006
First Prev 2 of 2
biglg
64
#21
  • May 3, 2006
  • #21
Thanks again.
Where should I add an additional ground? From what to what? Thanks, Landon.
biglg
64
#22
  • May 3, 2006
  • #22
I see where you say from the chassis ground to the engine block is recommended. DO you have pictures of this? Can you tell me more details exactly where these locations are, or where at on the chassis and engine block?
Will it be alright if I dont do an extra ground? I would like to, but if it requires getting underneat my car, I dont have the ability or equipment to do so. Thanks.
biglg
64
#23
  • May 3, 2006
  • #23
Ok,
I think I have this almost done, just waiting on my ANL fuse holder to get here in the mail. One last thing I need to do is put the belt back on. THis is the first time I have taken it off my car. What is the easiest way to get it back on? I was trying to put it over the alt pulley last. I messed with it for a few minutes and damn, I couldnt get it. Then the wife was yelling telling me to hurry up to go out to eat. I honestly dont think I can get the dam belt back on the way I was trying to do it. Can somone tell me exactly how to do it, what pully to pull it on last? I had to be trying something wrong, because i was 1/2-1 inch off, at least. Thanks guys.
HISSIN50
34
129
May 4, 2006
#24
  • May 4, 2006
  • #24
You could do the aux ground up top, or hold off on doing it. Jrichker has a cool post with all the ground locations and a pic of the stock battery and computer ground location on the driver side.
HISSIN50
34
129
May 4, 2006
#25
  • May 4, 2006
  • #25
biglg said:
Ok,
I also go over the alternator last. By doing this, the belt can be routed around the tensioner pulley beforehand so you dont have interferance issues with the breaker bar. You are using a breaker, and not running out of room to move the tensioner pulley, right?
Double check the routing if it doesnt seem like it will go. It can be a real stretch.
Good luck.
biglg
64
#26
  • May 4, 2006
  • #26
I dont have a breaker bar. I was using a socket? HUM. I dont know but I am not sure I can get the damn thing back on.
HISSIN50
34
129
May 4, 2006
#27
  • May 4, 2006
  • #27
The breaker can provide the extra leverage for some folks (I dont use a breaker normally, but I have a bit more mass than most folks). If you have a short piece of pipe, you can slip it over the end of your wrench to provide more leverage. Or even ask Mrs Biglg to come out and slip the belt on while you leverage the wrench.
Good luck.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
May 4, 2006
#28
  • May 4, 2006
  • #28
If you have a 3 ton jack, I use the upper half of the bar from that. Slip it over the wrench and use that for leverage. I am left handed so I route the belt around all the pullies except for the A/C compresser. I use two hands to get the tensioner up, then 1 hand to hold it and the other to slip the belt on the A/C pulley. The extra length of pipe really helps out here.
biglg
64
#29
  • May 4, 2006
  • #29
Thanks for the reply, an extra body would help. But my wife would say, that is your POS I am not touching it. I will find something tonight at the store to work.
I have a question about the fuse for the new 4 gauge power wire on a 3G Alt upgrade. I was planning to put this near the battery or solenoid, whichever I use for the power supply.
I read that some people are putting the fuse under the factory air box, which would make the fuse location closer to the alternator.
I always thought you wanted it closest to the power supply. Can someone confirm the best location for the fuse on the 4 gauge power wire from the 3G alt stud to the battery or solenoid?
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
May 4, 2006
#30
  • May 4, 2006
  • #30
The only reason that I put the ANL holder under the air cleaner was because I wanted a clean installation. When you pop the hood, I didn't want to see it. I tried to keep it close to the power source (alternator) because if the fuse needs to blow, I want it to go befor melting all of my wiring down stream....
biglg
64
#31
  • May 4, 2006
  • #31
strothfuss,
You have me confused. You are saying the fuse should be closer to the power source. You are calling the power source the alternator? i woudl call the power source the battery or solenoid whichever is used.
Just like in a car stereo amplifier install. You put the fuse within 1 foot of the power source, which is the battery, not the amplifier.
So I am guessing I want to put the fuse and holder within 1 foot of either the solenoid or the battery, whichever I end up using?
Thanks again for all of you help. I wouldnt have been able to complete this mod without all of your help.
HISSIN50
34
129
May 4, 2006
#32
  • May 4, 2006
  • #32
In this case, the alternator is the power source - it is what puts power into the battery and the current only flows one way. An amplifier is powered only by the battery (via the charging system, which is a tangent).
The fuse is to protect the electrical system in the event of an alternator short to ground or other failure. I wasnt as meticulous as Steve and did put mine closer to the solenoid. Closer to the alt is better though.
Good luck.
biglg
64
#33
  • May 4, 2006
  • #33
I never really thought of it that way, as the alternator as the powr source. I sure thought that I should have the fuse holder closer to the battery. I guess I will put it closer to the alternator if that is the best location. Thanks again.
HISSIN50
34
129
May 5, 2006
#34
  • May 5, 2006
  • #34
Like I said, I dont think it matters at all really. I've noticed that OEM circuit protection is often towards the battery or power distribution side of things (towards the battery, in your situation). FWIW, the fuse on my 88 is next to the ignition coil (real close to the battery side of things). Kinda proves that IMHO it doesnt matter too much, esp with the nature of how these ANL fuses burn.
Good luck.
speedytang
765
Marengo,Ohio,US
May 5, 2006
#35
  • May 5, 2006
  • #35
Just completed the install and ran into a problem that I have not had doing this in the past. My idle went up to 1400 rpm from 800rpm. I use a PMS and now for some reason I have a 0080 error coming up when the idle rises. I have made adjustments and it does not matter I can be driving then all of a sudden the idle is high and drive around come to a stop and the idle is back to 800 rpm.
smokin91'
204
#36
  • May 5, 2006
  • #36
Skip the 3G and look for a 6G. They are smaller then the 3G which means NO GRINDING the bracket, it just bolts into place. Also The wiring is simpler to hook up (you elimiminate the white/black wire totally). Plus its lighter, runs cooler and IMO looks better then a 3G in the engine bay.
First Prev 2 of 2
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Electrical Inaccessible starter solenoid from wire tuck, what are my options for an alternator upgrade?
  • AnthonyA1234
  • Jan 16, 2025
Fox 5.0 Mustang Tech Feb 8, 2025
Mindseye007
