Fox Body - Cougar Rear End
kube311
26
Woodbridge, NJ
Ok so I have searched around and have found nothing on this subject. I have a bent axle and the rear is making lots of noise on my 90 GT. I want to get new axles and a new carrier but I ran into a problem. Just did the rear brakes for the first time and found out that it does not have the stock rear or at least the stock rear drum setup on the car. Took a bit of searching but it happens that they are the 10 inch drums and or rear off the 88 cougar xr7. My car does have the quad shocks on the rear but so did the 88 cougar. Is there any way to find what rear this is so I can get the correct length axles?
just take the axle out and count the splines and measure the length of the axle. If they are stock fox length then you should be good to go.
