Fox MAS
Just wondering if a fox MAS will work on a 95? they seem easier to come by used as a match set with injectors. Not concerned with filter or piping connections, just electronics.
Of course, the mounting style is different
Electrically they are not all that much different as the transfer curves
are pretty close.
Why would you wanna go down in size from 70mm to 55mm :shrug:
or
What ever size it might be ... never the less ... I'm pretty sure its much
smaller in size :shrug:
On a side note about 94-95 mafs :)
The OEM meter will support more airflow
and
Easily go beyond the limits of fuel 19# inj will supply :eek:
Or In Other Words ... You'll run out of gas before airflow with the stocker :D
Grady
or
and
Grady
actually, I was planning on upping injectors to 24's to start, I see more avalible along the lines of sensors and sample tubes listed for fox bodies.Gives alitle more adjustability without the cost of buying recalibrated sensors every time you up injectors.
never know, 24's just might be the sweet spot for this combo, not sure what its capable of yet,just trying to planning ahead. :shrug:
