Fox parts left over
gtthunder50
I have some parts left over
MSD pro Billet Distributor with blaster coil $175
New Ford Racing red wires $30
Aluminum Radiator $115
New 373 Gears $100
BBK shorties and flowmasters $175
everything for a 5sp swap
T5 with bell housing short throw shifter new clutch flywheel clutch fork and 5sp pedals double hump crossmember and a adj cable $650
stock radiator with electric fan and thermostatic fan controller $50
3G alternator Swap 3G alternator 4 gauge wire and a 150 amp circuit breaker $150
Stock Bottom ends $40 each
Stock E7s $30
Complete 5.0L has like 80xxx miles on the rotating assembly new trick flow stage 1 cam new comp cams push rods new comp cams lifters 1.6 aluminum Roller rockers new timing set new gaskets 70mm BBK throttle body 19lb hi flo injectors under drive pulleys $800
have other parts so let me know
have more let me know my email is [email protected]
