  • 1994 - 1995 Specific Tech
Fox shortblock in a 95?
  • Thread starter Thread starter MustangGT95
  • Start date Start date Aug 17, 2006
M
MustangGT95
407
  • Aug 17, 2006
Buddy of mine totalled his 89 GT awhile back. Motor had 90k on it and it ran like a champ. I was thinking about offering him some cash for it if I can make it work. Anyway I can use the block/heads ect. I'm sure I willhave to change my intake and accessories but with the block itself work.
Sorry for the stupid questions. I'm used to Chevy's. Everything interchanges on a chevy. Just making sure I don't buy a block for nothing.
H
hurt
173
San Antonio, TX
Aug 17, 2006
  • Aug 17, 2006
Yep, block and heads will work just fine. Use the 95 accessories, sensors, egr, etc for simplicity.
blksn955.o
3,263
st.louis mo 314
Aug 17, 2006
  • Aug 17, 2006
pull out your stock longblock
remove brackets
put 94-95 brackets on the 89
drop in 89 longblock.
plug the lower intake ACT sensor hole.
either
A) do a fox tbody swap
B) leave off the fox upper and put on the 94-95 upper
start up and have forged pistons.
M
MustangGT95
407
  • Aug 17, 2006
Should be easy enough.
Next question...anyways I could run the fox intake setup and not have to use that stupid elbow that comes off the intake?
I'm wanting the forged pistons because I plan on a small shot of n2o.
blksn955.o
3,263
st.louis mo 314
Aug 17, 2006
  • Aug 17, 2006
Dont believe the hyp about the hyper pistons. They will handle 125shot with no issues...I have known people who ran a 150 shot on hypers with no issues after dozens of bottles. Its stilll good to know if you have forged though...
Do a search on the t-body swap and you will find a TON if info...its just easier to search than type.
M
MustangGT95
407
  • Aug 17, 2006
Thanks man.
I am not sure exactly what my motor is out of honestly. It is from a f150 I was told. Dad had it installed a couple years ago. It supposedly has a e303 cam also...but I have no idea for sure.
If I get a fox motor at least I would know what I had for sure.
diablostang
425
Raleigh, NC
Aug 17, 2006
  • Aug 17, 2006
One important thing to remember is, the Fox Body waterpump, timing cover and crank pulley are all different. You'll need to swap your 94/95 stuff on. And while you're in there, look at the end of the cam (on the timing cover side) If it has the mechanical fuel pump drive on it, REMOVE IT!!!! VERRY IMPORTANT. It's one bolt. If you don't remove it, you'll basically toast the whole engine/heads.
With that said, it's an easy swap, and it's worth it.
M
MustangGT95
407
  • Aug 17, 2006
Thanks for the heads-up.
18mustangs
533
Virginia Beach, VA
Aug 18, 2006
  • Aug 18, 2006
I did the Fox TB swap. If you need the instructions and part list PM me and I'll send it to you. Good luck with whatever course you choose!
Tim
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
T
Hi
  • timotto
  • Dec 14, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 14, 2025
91AOD5.0LX
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
