Do i need a fox vacume tree? can i see a picture of the way you routed your vacume lines?? The car will NOT have a smog pump or EGR so what vacume lines go where??
I also deleted the EGR and Smog pump, is that the set up i have to run then?? the brake booster and the PCV vac hoses should route the same as before right?? but where does the FPR vac line hook up too?? that's what i need a pic of i guess. Also this means i dont need a fox vac. tree right?>?
I have:
1. Upper intake to booster and factory vac tree behind the LH strut tower
2. upper intake to RH valve cover.
3. Upper intake to fuel press regulator
I have:
I'm not sure how many openings the TF upper intake has but on my Eddy, I just picked three openings and put screw in nipples in them and ran hoses to the above mentioned places. The other holes I just blocked of. No reason why I picked the holes I did other than they made for the shortest routing of tubing. If you do it that way you won't need the tree. Good luck
