Yellow302 Member Mar 2, 2003 789 2 19 NJ Dec 11, 2008 #1 Dec 11, 2008 #1 I need a new timing pointer to dial in the car and im not spending 60-90 buck on one. since its the same engine will it line up or do i need a different pointer?
Yellow302 Member Mar 2, 2003 789 2 19 NJ Dec 11, 2008 #2 Dec 11, 2008 #2 Yellow302 said: I need a new timing pointer to dial in the car and im not spending 60-90 buck on one. since its the same engine will it line up or do i need a different pointer? Click to expand... its just the water pump line up is different... looks like it should work
SQUEEZE&STROKE New Member Jun 24, 2005 0 0 0 SOUTHERN CA Dec 12, 2008 #4 Dec 12, 2008 #4 I have used a stock SN-95 timing pointer with a fox timing cover...Now if it is off or not...I will never know...
Yellow302 Member Mar 2, 2003 789 2 19 NJ Dec 12, 2008 #5 Dec 12, 2008 #5 SQUEEZE&STROKE said: I have used a stock SN-95 timing pointer with a fox timing cover...Now if it is off or not...I will never know... Click to expand... the lower bolt holes are identical, it is just the upper part that the water pump bolts to are different. Assuming so the timing pointer would be the same as well.
S sprintertech New Member Dec 9, 2007 25 0 1 Dec 16, 2008 #7 Dec 16, 2008 #7 you can bolt it up then put #1 tdc on compression and mark the crank pulley.....if memory serves me it doesnt locate as it should otherwise
final5-0 Mustang Master Apr 6, 2003 6,817 12 79 DFW Texas Dec 17, 2008 #8 Dec 17, 2008 #8 Yes put the #1 slug up top to know for sure ... tdc They used to make tape with timing marks you could stick on the hb ... don't know if it is around anymore Grady
Yellow302 Member Mar 2, 2003 789 2 19 NJ Dec 17, 2008 #9 Dec 17, 2008 #9 i believe my balancer is marked already, i replaced it with an after market one a few years back.
final5-0 Mustang Master Apr 6, 2003 6,817 12 79 DFW Texas Dec 17, 2008 #10 Dec 17, 2008 #10 The issue is not if the hb is marked The concern is the older fox pointer may not be the same as the 94-95 If that is so ... the marks on the hb could be off If you run your #1 piston to the very top of the hole ............ That is a known fact that You got top dead center thus You could mark the hb and that mark would represent ... TDC Grady
Bosko5.0 Active Member May 18, 2006 1,067 0 37 longwood, FL Dec 17, 2008 #11 Dec 17, 2008 #11 I used a ford racing 5.0 Hb it came with a pointer and I used that worked fine for me.
M mackey Active Member Jan 25, 2003 1,284 1 38 Beverly, Massachusetts Dec 17, 2008 #12 Dec 17, 2008 #12 Junkyard? How about the mustang junkyard online? You could email them and they will get one for like $5. CJ Pony Parts - Ford Mustang Parts Email them there and they will go in the salvage yard and get you one cheap!
