they claim to actually replace the trim...
http://www.foxresto.com/1987-93-Coupe-Quarter-Window-Reman-Service-p/21087012.htm
Screw all that. It was waaaay too easy of a DIY project to pay someone!
Close - High build primer, 400 grit. Repeat until pitting is gone and surface has the smooth surface you want. Spray with sealer, the SEM trim black. Takes a while, but requires little effort.Need to refresh myself on how to do it. I have a pair of windows I want to restore. Just flexbile body filler, sand, repeat?
Wow! What happened?It sounds steep, but it's probably worth it. Good originals are almost impossible to find now. I have a friend with a foxbody pushing near 6 figures cost wise who bought LMR replacements, and they didn't even last a year.
Kurt
Wow! What happened?
I redid mine, I am looking for another clean set to redo again. I could not bring myself to buy the LMR simply because they dont have the Mustang logo.
Everything he bought from LMR was made in China. None of it fits well, and the car leaks water like a colander.
I haven't had good luck with much of the LMR stuff I bought either. A lot ended up in the trash. You really are better off refurbing oem stuff vs some of the Chinese parts.
I'm curious to see actual quality of the molded windows. I bought a set of windows for $50 so not much to lose by refurbing myself...but a full rerubberizatiin sounds interesting
Where do you get your replacement mustang parts from when you can find NOS or quality used parts?I haven't had good luck with much of the LMR stuff I bought either. A lot ended up in the trash. You really are better off refurbing oem stuff vs some of the Chinese parts.
I’d also like to know. I need to replace all my weather strip after paintWhere do you get your replacement mustang parts from when you can find NOS or quality used parts?
