Electrical foxbody runs and then dies going down the road band you turn the switch back off and on and it fires right up don’t even have to crank back up
22dwatkins
Boaz
foxbody runs and then dies going down the road band you turn the switch back off and on and it fires right up don’t even have to crank back up. runs great and the randomly dies and will fire eight back up. has perfect fuel flow can’t figure out what the problem is.
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
17,244
5,530
193
polk county florida
Check the ignition switch under the dash, it's mounted to the steering column and has special screws that fasten to the column. This may help:
22dwatkins
Boaz
replaced the switch that’s not it
Potomus Pete
Is there a trick , or does my wife just hold it
Mar 7, 2019
1,092
370
93
56
Sarasota Florida
I would have somebody fool with your wires while you work the key. Or go with the no start check list. Coil , pip , control module. Give him the list . That saved me.
Rcdgl
125
37
38
68
Take all the stuff of the keyring and try it with just the key.
It may be just the switch and rack need readjusted. Been there done this.
Frankjbwr1
Trenton NJ
Had similar issue with my 86. Pulled the column cover and as I grabbed the wires going into the ignition switch the switch fell apart. New switch did the trick. Seems to be a common problem..
BlakeusMaximus
Still got to try a little lube on my speedo head
Jul 12, 2017
1,955
1,137
163
I would bet on the switch as well. Even if it isn't, and its the original, replace it.
Foxslider
im not that much of a idiot
Oct 25, 2019
438
120
53
33
Houston, TX
Here's 1 idea, check that the coil mount, where it screws into the fender is tight. It might appear and feel tight and grounded but its a not a very solid and tight ground/connection. Mine would start, then not.. And i remounted the coil tightly and has been consistent now.
Thread starter Similar threads Forum Replies Date
1986oxfordwhite 1986 Gt Runs For About 45 Mins Dies, Cools And Restarts Again? Fox 5.0 Mustang Tech 4
M Electrical 1989 mustang 5.0 runs rich and stumbles in closed loop Fox 5.0 Mustang Tech 10
C Engine Gray smoke from exhaust. Smells like gas. Fox 5.0 Mustang Tech 15
8 Plz Help! ‘88 Mustang will not idle and runs poorly Fox 5.0 Mustang Tech 4
Z Engine 88 foxbody not running Fox 5.0 Mustang Tech 4
D Electrical foxbody won't start without starter fluid, starts and runs fine for a few days Fox 5.0 Mustang Tech 2
J Engine 93 lx 2.3l runs terrible 2.3L (N/A & Turbo) Tech 9
R Engine 1989 LX - Engine Trouble Noise & Rich - Help Appreciated Fox 5.0 Mustang Tech 8
S 1988 foxbody lx running rich Fox 5.0 Mustang Tech 6
B Help with 88 foxbody Fox 5.0 Mustang Tech 2
B Need Help. Foxbody Running Pig Rich Fox 5.0 Mustang Tech 5
killer5.0 Boosted Foxbody...running Rich...unhooked Maf...no Change In Engine Fuction? Fox 5.0 Mustang Tech 6
U Foxbody Run Out Of Fuel No Crank Anymore Fox 5.0 Mustang Tech 6
plantmeister Car Running Hot Fox 5.0 Mustang Tech 62
N First Foxbody, Getting Her Running And Back To Her Prime! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
Benz510 Fox What Kind And What Group Size Battery Is Everyone Running In Their Fox Body 5.0? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
Fastfox619 Saleen Vortech intake, anyone running one on their foxbody Fox 5.0 Mustang Tech 27
jonathon reynolds 92 foxbody gt running rich all the time. NO POWER Fox 5.0 Mustang Tech 42
C 357W in a foxbody, running issues.. help Classic Mustang Specific Tech 1
BlackFox5.0 Anyone here running Dual Piston PBR Calipers? (foxbody) Fox 5.0 Mustang Tech 10
G "89 Foxbody 5.0 turbo boost amount? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
D ECU and Wiring for a foxbody swap SN95 4.6L Mustang Tech 3
T Aod transmission dipstick question Fox 5.0 Mustang Tech 3
Q New to Stangnet/Restoring '86 Foxbody GT 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
T Aod transmission no OD Fox 5.0 Mustang Tech 16
R Non EGR swap on 92 foxbody Fox 5.0 Mustang Tech 15
Boostedpimp Fox 93 Foxbody Coupe value 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
D Idles Fine, Rev engine High Manually, engine comes down and dies. 2.3L (N/A & Turbo) Tech 0
J Brakes Foxbody brake Booster Fox 5.0 Mustang Tech 0
T Wing and luggage rack 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
D stock rocker arms breaking The Welcome Wagon 2
A Used Foxbody Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
O Digital Tuning Anyone know this Superchip? Fox 5.0 Mustang Tech 3
D Foxbody torque box reinforcements 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
W New guy, 1989 foxbody The Welcome Wagon 1
S 1993 Mustang 2.3 L Automatic A4LD Transmission - Help 2.3L (N/A & Turbo) Tech 2
M Engine 87 Foxbody Hesitation at High RPMs Fox 5.0 Mustang Tech 15
D 1989 Dash Harness Problems Fox 5.0 Mustang Tech 2
F Advice needed for Foxbody build 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
9 92 foxbody front disc brakess Fox 5.0 Mustang Tech 1
T 93 convertible torque box reinforcements 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
B [Project Car] 1986 5.0 V8 Foxbody Mustang Starting Issue Fox 5.0 Mustang Tech 8
S 391 swap into foxbody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 24
5 Powersteering Pump replacement gone wrong Fox 5.0 Mustang Tech 15
F Brakes Hydro boost foxbody Fox 5.0 Mustang Tech 8
8 Electric fan problem Fox 5.0 Mustang Tech 2
Waz900 Brakes Foxbody SN95 Booster install Question Fox 5.0 Mustang Tech 3
A Car starts but dies Fox 5.0 Mustang Tech 2
8 Coolant leak Fox 5.0 Mustang Tech 4
spiegs throttle cable removal and install Fox 5.0 Mustang Tech 8
