Freakin T/As
darkhorse1
121
Indiana
My car runs pretty good, but it's everything that I can do to keep up with my friends 01 T/A. He has a true ram air kit,true dual exhaust (turned down), and a 3500 stall with d/r s. He kills me out of the hole,but he doesn't gain any distance on me once we are going(still 2 cars ahead though). I stay right with him at a roll. If I put slicks on should I be able to beat him, or what will I have to do?
Tough call,
I have these mods on my 97, pretty similar, and I rarely lose to them.
AJE K member
Lakewood 90/10 struts
D&D coil overs
UPR caster/ camber plates
Sub frame connectors
Upper/ lower control arms
TKO 600 transmission
Custom clutch
Built rear end 31 spline diff.
FRPP 4.30 gears
Lakewood rear shocks
UPR solid motor mounts
Bassani ceramic mid length headers
Bassani catted X pipe
Steeda mufflers dumped
MSD plug wires
255 Walbro fuel pump
C+L mass air meter and inlet tube
ASP underdrive pulleys
1) better tires will help, but if he is that setup for drag (IE stall+slicks) you dont stand much of a chance unless you are setup close to the same. your 4.1's will help if you can transfer that power to the ground during the first 60ft.
2) Spray. if once you guys are moving he cant get an edge on you now, if you get a bit of juice flowing, you can probably put quite a pull on him. Even if he outlaunches you, with a decent amount of juice, you might be able to not only catch him before the end of the 1320, but pass him up as well.
3) A set of Longtubes would be nice as well, help your overall performance.
