front brake conversion help
  • Thread starter Thread starter jmd2914
  • Start date Start date Jul 8, 2006
J
jmd2914
937
Napa, California
Jul 8, 2006
  • Jul 8, 2006
I already have a five lug/ 4 wheel disk conversion but it was done back in the day using the lincoln brakes. what all do i need to change to get some new front brakes that will allow me to get some rims that look good. ( dust cap is in the way)
Dayzed50
106
Marysville, WA
Jul 8, 2006
  • Jul 8, 2006
Dust cap clearance problems have plagued consumers and wheel manufactors for years on the fox bodies with either factory 4-lugs or older 5-lug designs. The only fix I am aware of is converting your front spindles/rotors to '94 or later SN-95 style which opens a ton of possibilities for wheels. Baer brakes packages it's front brake kits with these spindles for fox bodies. There are a couple of aftermarket companies that sell 5-lug rotors for your style spindles but I believe they couldn't fix the cust cap issue.
Mustang5L5
Mod Dude
Feb 18, 2001
43,377
18,123
224
Massachusetts
Jul 8, 2006
  • Jul 8, 2006
He already has 5-lug on his Saleen. They come with SVO style brakes.
Because of this, you may run into problems with offsets. The rear disks are 1.25" wider each side. On the SVO, they use longer front control arms to match the rear offset so they can run the same size wheels up front. Saleens i think use a staggered offset wheel setup?? Unsure on that but if they don't then that means the front control arms are longer.
I know 2005+ Wheels will fit on the SVO's and the offset works great. MM&FF put a few different types of 05+ wheel on including the bullitts and they seemed to make it seem like it was a direct bolt on. SOme 05+ bullitts or 06+ 18" wheels might look cool on the Saleen.
bill302
2,131
alabama,gadsden
Jul 8, 2006
  • Jul 8, 2006
click on link below and see if it will help you...
http://sn95brakes.com/sn95brakes.php
J
jmd2914
937
Napa, California
Jul 8, 2006
  • Jul 8, 2006
so the 05 wheels will bolt right up? i was thinking about putting bullitt rims on it but i wasnt sure yet. but if they'll fit i might just go with those
Dayzed50
106
Marysville, WA
Jul 8, 2006
  • Jul 8, 2006
I bolted a set of bullets onto an '86 lx with the lincoln/svo 5-lug conversion but we couldn't put the center caps on the front, dust cap issue. car still looked sharp though
J
jmd2914
937
Napa, California
Jul 8, 2006
  • Jul 8, 2006
so the wheels will fit i just can run a dust cap?
Fox Traction control
  • Sparky714
  • Nov 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:43 AM
Sparky714
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
