front brake pads ???
  • Thread starter Thread starter jadigen
  • Start date Start date Mar 28, 2013
1 of 2 Next Last
J
jadigen
132
S.Jersey
Mar 28, 2013
  • Mar 28, 2013
whats everyone using? have a 87 lx 5.0. its all stock. i needs something that performs well but also want something that doesn't throw a ton of brake dust...
what do you guys recommend?
thanks in advance....
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Mar 28, 2013
  • Mar 28, 2013
hawk HPS
J
jadigen
132
S.Jersey
Mar 28, 2013
  • Mar 28, 2013
srtthis said:
hawk HPS
think they are better then anything that a napa would sell??
thinking these would work for me.. http://www.americanmuscle.com/ceramic-8793-v8-frontpads.html
is there a better place to buy them other then american muscle?
srtthis
5,129
1,666
204
Maryland
Mar 28, 2013
  • Mar 28, 2013
they stopped my 5000lb lightning from 150mph a few times and never gave me issues... they should stop a fox body just fine
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 28, 2013
  • Mar 28, 2013
srtthis said:
hawk HPS
X2. ^
Wagner Thermo quiets are nice stock replacements as well. Avoid any poop boys, Advanced Auto or any house brand pads. Don't forget the disc brake pad anti squeak spray or gel. I always at a minimum turn my rotors if they are within spec or replace with new ones, repack the bearings with fresh grease, and check the calipers and hoses for leaks. Spray down the rotors with brake clean after you get them back from the machine shop or even new ones to remove any crud, film, or grease marks. Make sure you preload the bearings with a torque wrench after install.
While you are at it think about replacing the following, as it makes a noticeable improvement in braking for not much $$$
-replace the stock 25 year old hoses with a new set- SS is a nice upgrade-
-SS caliper bushings for the bolts
-Lincoln MKVII 73MM calipers- bolt right in vs the stock 60MM calipers.
J
jadigen
132
S.Jersey
Mar 28, 2013
  • Mar 28, 2013
thanks guys.. i have new rotors, bearings and seals here already. need the advice on the pads...
just looked up the hawk pads. they say low dust so maybe i'll give those a try...
probably changes the hoses while under there too since like stated they are 25 years old. still gathering the parts to do it nice the weather breaks..
aar0s
1,015
55
69
Mar 28, 2013
  • Mar 28, 2013
I used the hawk pads but I also installed some Maximum Motorsports braded lines, made for a nice fade free stop.
David Pepiton
662
68
49
Laveen, Arizona
Mar 28, 2013
  • Mar 28, 2013
a good quality ceramic like wagner, performance friction, akebono, Hawk or EBC will all be fine at the same time however i would replace your rotors with some better then stock units like bosch quite stops, EBCs, brembo or stoptech.
srtthis
5,129
1,666
204
Maryland
Mar 28, 2013
  • Mar 28, 2013
I'm going to suggest against ceramics... They make a lot of heat and push it into the rotor.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 28, 2013
#10
  • Mar 28, 2013
  • #10
True, but that is the trade off with better stopping power, less dust.squeaks. If you have to brake hard, just drive normal for a few minutes to let the brakes cool off. I've run ceramic pads for years and never had a warped rotor. Also, it is critical to break in the pads properly when you first install them with a series of 35-5 then 55-5 stops.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Mar 28, 2013
#11
  • Mar 28, 2013
  • #11
srtthis said:
hawk HPS
^^ x3
srtthis
5,129
1,666
204
Maryland
Mar 28, 2013
#12
  • Mar 28, 2013
  • #12
I ran ceramics for about 5000 miles on the lightning blew threw a red light from brake fade from heat. That's the first and last time I ran ceramics . I'll deal with dust
Way2QWK
62
Tucson, AZ
Mar 28, 2013
#13
  • Mar 28, 2013
  • #13
Im happy with Performance Friction.
David Pepiton
662
68
49
Laveen, Arizona
Mar 28, 2013
#14
  • Mar 28, 2013
  • #14
I pulsate my brakes anyways so brake fade really doesn't bother me.
J
jadigen
132
S.Jersey
Mar 29, 2013
#15
  • Mar 29, 2013
  • #15
Thanks for the replys guys.
The car is only a family cruiser that is only used on nice days. Figure once I do the brakes I won't have to do them for a long time. Car is lucky to get 5000 miles a year put on it.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Mar 29, 2013
#16
  • Mar 29, 2013
  • #16
EBC pads on my Mustang as well as my daily driver Volvo although i dont recall if they are the green or red
StreetsideStig
1,012
48
48
Mar 29, 2013
#17
  • Mar 29, 2013
  • #17
I'll throw in a vote for EBC. I really like mine.
srtthis
5,129
1,666
204
Maryland
Mar 29, 2013
#18
  • Mar 29, 2013
  • #18
prob green's i ran them on my 95 and my lightning at first. they stopped great just a lot of dust
StreetsideStig
1,012
48
48
Mar 29, 2013
#19
  • Mar 29, 2013
  • #19
Yeah, Greens will make more dust than the Yellows, which I'd recommend, depending on the application. I did a write-up on them once, after interviewing one of the top guys at EBC in the US.
madspeed
Colonel Mustard
1,332
204
Mar 29, 2013
#20
  • Mar 29, 2013
  • #20
pretty sure ive got the red stuff. Low dust on them babies
edit- yep EBC Redstuff here
1 of 2 Next Last
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
