Front Bumper on a GT
Take off the entire assembly. Drill out all the rivets, cover comes off, new one on... rivet it back up! It's pretty straight forward, just hit every bolt/nut that holds the assembly on there.
Good luck.
the rivets are only to hold the headlight bracket thing to the bumper. to remove the bumper from the car, you have to remove the 20-22 bolts that hole it on. 2 are attached to "L" brackets right near the latch (4 if you remove the brackets too), 4 underneath the car that also hold the mudguard.air deflector on, 6 one each of the fender/bumper joint (12 total) and it migh also have another 2 bolts doen near the frame rails right near the back of the headlights.
The rivets can be drilled out and replaced withthe bumper off the car.
I have to drill out rivets while the bumper is on the car don't i?
All the rivets do is hold the headlight bracket to the urethane cover. You can take the whole thing off in one piece. Theres a few bolts across the top that go to the radiator support and some smaller ones on the inside of the fender wells that bolt to the front fender extensions. The whole thing will pop off w/ the headlight bracket still attached.
The headlights come off with the bumper or your saying the headlight bracket?
Kind of confused Prime, also so i have to remove headlights before taking off bumper or no?
Thanks in advance, Nick
If you leave the headlights in and just unbolt the brackets going to the radiator support and then the small bolts in the fenders the whole front end will come off headlights and all. The link you have at the top is just the cover and does NOT include the headlight bracket. So once you unbolt the front end and take the whole unit off, you will have to remove the headlights and then drill out the rivets for the headlight bracket. That headlight bracket needs to then be re-riveted into the new cover and the headlights reinstalled. From there you can bolt the whole front end back on.
Does that help?
Does that help?
So it seems as if ihave to disconnected all wiring going to headlights. and then wen i have the bumper off with the headlights still connected i have to drill out the rivets yea i know what rivets ur talking about but not what "unbolt the brackets going to the radiator support/ can you show me a picture of the headlight bracket?
Yeah, youwill have to pull all the bulbs out of the headlights so that there is no wiring to them.
Its not my car, but you can see the same thing. There are two of the support and a SLEW of the rivets that hold the headlight bracket to the bumper cover.
after reading your last post you wrote thatthe headlight bracket would have to be re-riveted in but it looks like it is using bolts to both sides.
So all i have to do is all the fender bolts and under the bumper bolts and then the 4 bolts for the headlight bracket(s) and the front end should just come off no problem?
You've got those two bolts in the angle brackets that go the radiator support (marked "brackets" in the pic) and then theres 3 or 4 bolts on each side that hold the whole front end to the fenders (you can get to those from the inside of the fender, and therefore cannot be seen in that pic) and then the whole front end comes off headlights and all. Once you've got that whole front end off, unbolt the headlights, and those rivets must be taken out in order to separate the headlight retaining bracket from the actual bumper cover (the piece you got off of ebay). The cover is super flexible and thin up on top of the headlight bracket which is why there are so many rivets. The headlight brackets must then be re-riveted into your new cover, the headlights remounted, and then the whole cover w/ the headlights can be bolted back on the car.
Its not that big of a job. You just have to get the replacement rivets to hold the new bumper cover to the headlight bracket.
I don't remember 100% but I don't think there are any bolts under the bumper cover itself. The foglight bracket is mounted to the actual fiberglass bumper, so thats going to stay on the car when you remove the front end. Does that help at all?
Am I missing anything? someone else care to chime in?
