I live in Mapleton Depot, PA (central PA).
I RULE!
Note: Do NOT try to torch the bolts off. NEVER! Who ever suggested that NEVER tried it. Well, I did. You do NOT want to do that!
TRY to bang the bolts out. It will take you a LONG time to cut through the hardened sleeve and the grade 8 bolt. Plus, you have to make SURE you don't start cutting into the k-frame.
If you could do the cuts from underneath, it would be a LOT better. But, unless you have a lift, you're able to use only a SMALL portion of the blade. So, you go through a LOT of blades VERY quickly. ~70% of the blade is still good, but you can't use any of that portion because of space limitations.
Also, get GOOD blades. Those cheap *ss blades do NOTHING! The cheap Sears blades snap very easily. WEAR GOGGLES and PROTECTIVE clothing. Blades WILL snap!!! The blades WILL bind. Pieces of metal WILL FLY EVERYWHERE *WHEN* the blades break.
I had to cut 3 out of the 4 bolts. Yea, MAJOR SUCKO!!! You'll need to do *2* cuts per bolt. Once you get the FCA out, you'll likely see that the bolts and sleeve are *one forever*. People that don't live in snow states can't fully comprehend the effects of rust and what it means for to be "rusted together FOREVER"!
My driver's side spring rusted to the FCA and broke. The passenger side spring wouldn't come out even with a torch and a huge pry bar. (I just wanted to get the spring out to see the length) One of the *12* Springs that I have is also a broken Fox GT spring. Just imagine the force needed to *break* a spring. THAT is what I mean by "rusted forever".
Good Luck. I found that the Demo blades worked the best. Expensive, but they work the best. Buy them in the multi pack at Home Depot. Sears & Craftsman blades are a joke. Sears blades are junk. Do NOT use them. They grenade like crazy! Craftsman blades are just poor and wear quickly. But, at least they "kinda work" for a short time before they get dull. On Sunday night, Sears was open and Home Depot was closed. Oh well, I went through at least twice as many Craftsman blades per cut. But, I did get the bolt cut.
GOOD LUCK!
