Front end bushings
Black Sun 5.0
1,337
L.I., N.Y.
I'm getting ready to start 'the project' on the '90 I picked up last month. Bone stock. So bone stock that when I opened the hood I didn't recognize anything under the hood. Anyway, the engine will be out and I figured it would be a good time to swap out the old rubber bushings in the front end with some poly bushings. How big of a pain is it to perform this swap? Does anyone out there sell a kit to do the whole front end or specifically what bushings should be replaced? Also, are there any suspension parts that should be swapped/upgraded while everything is out? I'm not replacing the k-member.
Energy suspension ( http://www.energysuspension.com/pages/must1.html ) should have a kit for the front of the car. You will have to measure the front sway bar diameter to get the proper bushings for it. The swaybar bushings come in two flavors, one with grease fittings and one without. The difference is a lot more than the $1.50 worth of grease fittings. I drilled & tapped my original metal brackets to take the grease fittings and saved some money.
Try this from Summit:
http://store.summitracing.com/egnse...0+4294908331+115+4294908282&Ntk=KeywordSearch
That should give you a whole list of bushings and parts to choose from.
I agree - do it all.
If you need LCA bushings and ball joints, I'd consider the 3075 arms instead. Nice HD BJ's, nice new bushings (though not quite of the durometer rating of poly), etc. Not a bad way to do things. I was not all that happy with how the poly LCA bushings felt on the front. I run Delrin on another car (double wishbone front end) and Love it. I should have gone more that route instead (harshness is about the same but without the deflection or binding of poly). Neat stuff.
I'd consider the BJ's, LCA bushings, anti-sway bushings, end links, the rack (if you do it, get some decent aftermarket rack bushings. The reman'd rack I got came with the wrong bushings anyhow), outer tie rods, etc.
And while in there.......... springs, spring isolators, struts, etc.............
It's wonderful how the projects snowball. :D
Good luck.
I'm going to worry about the struts and springs slightly further down the road, but still probably before the springtime. I've been told that the front end bushings are a pain in the butt to replace, so I figured I'd take advantage while everything was out of the car.
