Front End Suspension Help
  • Thread starter Thread starter 70grande
  • Start date Start date Feb 3, 2009
70grande
56
San Diego, CA, 92115
Feb 3, 2009
  • Feb 3, 2009
Hey, so I have a 1970 Mustang Grande and my front tires have been squealing and wearing really fast and when I took the car to the local shop to get the tires alligned he said that I "need front end suspension work" and that he couldn't allign the tires but he tried anyways and made it worse. I can see where the bushings for drivers side lower control arm have been smashed and it bent the part where they connect to the frame. The moron at the tire shop refused to say anything but front end suspension work. What exactly do I need to do and dont say take it to a mechanic cause I got sick of getting screwed over and I do all my own work now, regaurdless of difficulty.
Thanks for the input!
Tim
BarnStang
1,260
Hagerstown, MD
Feb 4, 2009
  • Feb 4, 2009
You can get a complete front suspension rebuild kit from any of the mainstream mustang vendors. We normally work with Kentucky Mustang, but any of them have it like Virginia Classic Mustang or CJ Pony Parts. Kentucky Mustang 1-888-861-0176
Hack
1,945
Minneapolis
Feb 4, 2009
  • Feb 4, 2009
If you want to be certain exactly what needs to be replaced you have to tear it apart and examine the pieces. Check the ball joints. Probably the upper control arms are going to be toast if it's been a while since you've been in there. I really despise Ford's design UCA. They seem to loosen up and squeak very quickly - at least with the way I drive.
Might be a good time to put roller bearings in there, at least in the spring perches. Opentracker Racing Products!
rbohm
6,698
550
204
tucson,az
Feb 4, 2009
  • Feb 4, 2009
i also think the best thing is to get a complete kit to rebuild the front suspension. and i also agree with hack that the upper arm bushings bite big time.
BarnStang
1,260
Hagerstown, MD
Feb 4, 2009
  • Feb 4, 2009
Of course if funds permit, put a Total Control setup in there...
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Feb 5, 2009
  • Feb 5, 2009
Just put a stock pair of upper arms in there, a stock pair of lower arms in, open tracker roller perches, a new set of nice shocks and a decent size sway bar with some fresh bushings. Oh ya, and don't forget to replace your strut rod bushings.
Now, how good of a mechanic are you ? What kind of tools do you have ? Do you have any friends that are good at working on cars ?
shelby69
100
allentown
Feb 8, 2009
  • Feb 8, 2009
I have a 69 coupe and had similar problems. I changed the whole front end (ball joints, bushing, tie rods, the whole deal). Afterwards it was better, but still no good. It would be fine for a little while and then do the same thing. Turns out, the problem was a crack in the shock tower. I know, I know the shock towers suck. The crack was allowing the control are to move a little bit, thus changing the alignment. I repaired the tower got it re-aligned and it has been fine.
Check it real close make sure you are not missing something like that.
Good Luck!
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
