front rotor upgrade
I have Brembo front rotors on my car, drilled and slotted. Got them on Ebay and they are great. Along with Performance Friction ceramic pads, I get no fade.. Granted, I do not use it for autocrossing, but they work 10000 times better then the stock rotor/metallic pads I had on it before, inwhich would fade like a mother just getting off the interstate.
Nick
86bluecobra said:
All it may help with is brake fade. If the rotors can vent better you could have less of the fade othere then that you still have the same clamping force as you always had.
Except that crossdrilled rotors don't vent any better. The crossdrilled holes are so gases from exotic race-style pads have a place to escape to.
Since modern street car pads don't vent gases, crossdrilled holes are useless on the average street car.
Best performance is from plain faced rotors. They cool better due to having more mass to distribute the heat of the rotor more evenly
I've always been confused hearing that street pads don't vent gasses. I've seen lots and lots of regular stock replacement pads that when used hard are smoking like hell, and they leave a liquidy film residue on the surface of the rotor.
Maybe the smoking isn't gassing out, but more along the lines of cooking due to the heat. But forget the smoke, it's that film that I get concerned about.
Well, venting gases during normal braking and smoking the brakes due to high heat situation are different animals really. If you are riding your brakes hot enough to get them smoking, crossdrilled holes aren't really going to help you.
Back in the 50's and 60's street brake pads were made of different materials that expelled gases when used normally. I'm talking normal everyday stopping. It wasn't enough to be visible though. Modern pads do not vent anything anymore other than dust. Exotic style race pads still do however, this is why most race cars you see do have some sort of crossdrilled rotor. It has nothing to do with cooling as airflow through the vents is actually quite poor due to being perpendicular to the main centrifigal cooling vanes inside the rotor.
There is data that crossdrilled holes DO help with high speed braking (over 100+MPH) from data from GM, but those are 13" and 14" crossdrilled brakes.
Most street cars have 9-10" brakes. Crossdrilling these is NOTHING like the crossdrilled rotors on a Porsche or Z06 or something.
Thanks, that's some information I didn't know.
I figured the smoking was different than gassing out.
The liquidy film I get when I really abuse some brakes though does make me lean towards getting crossdrilled or slotted rotors for that sort of use.
Since we're on the topic of cool brakes. Has anybody else seen the scalloped rotors? A picutre is worth 1000 words so I'm not going to bother trying to explain how they work.
http://www.randys-racemart.com/scbrro.html
I gotta get me some!
