  • 1994 - 1995 Specific Tech
Front Strut install question
  • Thread starter Thread starter tderrick
  • Start date Start date May 3, 2005
T
tderrick
312
May 3, 2005
  • May 3, 2005
Getting ready to install my Bullit suspension kit and want to make sure I understand everything before I go in...
The first question I have is... why do I have to unfasten so many nuts and bolts
on top of the strut? It says to undo three. Doesn't the strut just stick through with the long rod with just the one big nut holding it on? why undo the whole plate?
N
Nagash01WS6
402
Deland, FL
May 3, 2005
  • May 3, 2005
If you are only doing the strut... just crack the nut on the strut loose. You will throw your alignment out of whack otherwise.
slytherin
702
northeast ohio
May 3, 2005
  • May 3, 2005
It is just the nut on top and the two on the bottom to undo the strut. The two bottom bolts were PITA's on mine hit them wit a generous amount of penetrating oil and have a good breaker bar to get them undone.
T
tderrick
312
May 3, 2005
  • May 3, 2005
Thanks, guys!
That's what I thought. I couldn't see undoing the whole plate just to get the strut out. I thought I had the wrong part or something...
94-302-vert
1,947
NE CT
May 3, 2005
  • May 3, 2005
On mine I used heat (mapp gas torch) to heat the nuts a but on the lower bolts then sprayed them with WD40 to cool them, then reheat and cool a couple times per and they came off without too much trouble (jsut my 18" long ratchet).
Chris
WHITE94COBRA
816
HUNTINGTON BEACH
May 3, 2005
  • May 3, 2005
No need to remove any other bolts, however I would still recommend getting your car aligned after you put them on. Just a precaution. not even sure you need to do it right away, but I always have.
94-302-vert
1,947
NE CT
May 3, 2005
  • May 3, 2005
after doing springs too you will need an alignemtn. leave the factory C&C plates in place and that will get you to the alignment shop.
Chris
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
