  • SN95 4.6L Mustang Tech
Front Struts
  • Thread starter Thread starter N8Dogg98
  • Start date Start date Jun 23, 2005
N8Dogg98
3,872
238
184
MN
Jun 23, 2005
  • Jun 23, 2005
I am having difficulties installing front struts myself and need some assistance. The car they are going into is a 1998 Mustang GT stick shift. I removed the stock struts, however I could not figure out how to remove the top nut holding down the rubber bushings and the dust cover. I am sure it can be done I just couldn't figure it out. Is there a special tool, or technique to doing this, and is reinstallation the reverse of removal? Thanks your comments are appreciated.
9646gt
595
Holloman AFB,NM
Jun 23, 2005
  • Jun 23, 2005
not sure if you can but could you remove the three bolts holding plate and all and then try to remove it? I think you will have to use an impact wrench to really get it out but then agian I havent looked closely at it..
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 23, 2005
  • Jun 23, 2005
Do not remove the three bolts. You will lose your alignment.
If you have a slot in the end of the threaded shaft of the strut put a huge screwdriver in it to get it to stay still. If it has flat sides use a large pair of vice grips.
The easiest way is with an impact wrench.
9646gt
595
Holloman AFB,NM
Jun 23, 2005
  • Jun 23, 2005
I have rivets holding mine in alignment?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 23, 2005
  • Jun 23, 2005
Yeah, there are rivets if it is factory stock but there is really no need to remove those three bolts. It will be more work in the long run IMHO. He should focus on getting that top nut off IMHO...
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
