Front Suspension Questions
Yeah, it will have the effect of making it handle a lot better. It might sit a hair higher than advertised without the weight of a 5.0 in the front, but not enough that you would notice it. My only warning is that you usually need adjustable caster camber plates to get the alignment right on the car after it's lowered, so budget that in.
Kurt
With the CC plates, you'll want to match your year of car...so get 90-91
Basically, for the front suspension, you'll want:
87+ Spindles brake rotors, bearings, seal, calipers, pads and brake lines
87+ struts
90-93 caster camber plates.
The sway bare is different, but unsure how running the stiffer 5.0 front bar will effect the handling dynamics of the lighter 4-cylinder. You can also add the 5.0 rear bar but the same applies.
87+ struts
Awesome. Thanks for the input. I will eventually be running a 5.0, but for now I want to finish the rest of the car. Driveline will be the last thing I do.
