Front sway bar mounts
  • Thread starter Thread starter TrophyHead
  • Start date Start date Jul 16, 2004
TrophyHead
1,195
11
49
PA
Jul 16, 2004
  • Jul 16, 2004
I have a question concerining my front sway bar. I notced one of the brackets that hold the sway bar up is snapped. I got new end-links installed on the car a while ago. It just seems like my sway bar is out of wack about an inch and it won't move to the correction location where my broken bracket is. I probably could Gorrila the sway bar so it fits in the stock location but its pretty rigid. Could my lowering springs be the promblem?
I'm gonna buy a new braket but I dont want it to snap again. Is there anything else I should check out? The sway bar it self looks soild and is not bent or anything.
Any idea's? Thanks
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jul 16, 2004
  • Jul 16, 2004
just take it out
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jul 16, 2004
  • Jul 16, 2004
With the end links in place you won't hardly be able to move it. If you take them off you should be able to reweld the bracket and be all set. They do seem to snap sometimes, not terribly uncommon.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 16, 2004
  • Jul 16, 2004
I forgot what company made them but there are sway bar bracket reinforcements made. Probally UPR or Wildrides, I really don't know because I relocated the front swaybar to the attic.
TrophyHead
1,195
11
49
PA
Jul 17, 2004
  • Jul 17, 2004
Allright I was thinking about ditching the sway bar all together. But I'm afraid of the response on the street. I'll look into those reinforcements. Thanks for the replies.
Dark Knight
2,578
Chandler, Az.
Jul 18, 2004
  • Jul 18, 2004
I've broken mine twice
off right now till I get time to get back in there and try again to get it to stay.. it's not bad without it.. corners like crap of course.. but not to bad.. but I will put it back on.. I'll have to look for those braces.. the factory spot welds just arent enough
stangbear427
2,401
New England
Jul 18, 2004
  • Jul 18, 2004
MM makes them:
http://maximummotorsports.com/frontswayreinforce.asp
5ptslow
105
Westland, MI
Jul 18, 2004
  • Jul 18, 2004
my drivers side snapped off i just rewelded it back on
85GTlover
704
  • Jul 18, 2004
I took mine off and put a bar from from rail to rail in the front by the rad to help make up for the loss. Just the A arms are not tied to each other anymore, but having the front frame rails tied in should help a lot. It was easy, I just used an old curling bar, cut to fit. Looks sweet, but I have yet to test it, as I need a clutch.
ironmedic
1,361
Puyallup, WA
Jul 18, 2004
#10
  • Jul 18, 2004
  • #10
take the sway bar off and install it as a wing on the back of your car. its the new ricer style!
TrophyHead
1,195
11
49
PA
Jul 19, 2004
#11
  • Jul 19, 2004
  • #11
That would look great on my new 90 MX-6. It's pretty fast well not that fast but Im not worried about other ricers while driving it. Which is good thing.
I'm gonna order the MM reinforcements really soon.
bossmstng302
52
phoenix, arizona
Jul 19, 2004
#12
  • Jul 19, 2004
  • #12
trophyhead nailed it right on the head. the stock swaybar box is only spot welded onto the frame, and is prone to breaking with age and definately hardcore cornering. maximum motorsports sells a reinforcment kit for only $15. problem is you gotta have it welded in if you dont have access to welding equipment. i figure it wouldnt be too expensive to have a shop do it. i did it on my buddie's lift w/ my own welder and it took about 1/2 hour to do.. thats with preparing the surface, painting the new welds/bracket and cleanup. it looks pretty damn sturdy now i i dont think i will have to worry about it ripping off when i am bombing around chicanes/
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Fuel 87 5.0 Fuel rail lines
  • Mcmahst
  • Jan 21, 2025
Fox 5.0 Mustang Tech Feb 11, 2025
Mcmahst
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
