I recently got my 347 up and running in my 65 fastback. Everything is great except for an oil leak that is slinging oil all over my newly painted engine compartment. I used a late model 5.0 block with a timing cover from a 70's 351w. Before I go and pull everything apart, is there anything obvious wrong with this combination? I had the shop that built the short block install the cover for me and I don't recall if there were dowels involved that would locate the cover on the block. Is it possible that there is a mis-match between these parts that is causing my problem? The oil is definitely coming from the front crank seal - it is getting onto the dampener and getting flung outwards around the engine compartment. Any help would be greatly appreciated.
