  • SN95 4.6L Mustang Tech
Front tires rubbing???!!!
  • Thread starter Thread starter zebra23
  • Start date Start date Mar 26, 2006
Z
zebra23
  • Mar 26, 2006
On my 98GT, the front tires have just recently started to rub on the sway bar when making tight turns. My car has been lowered running 17x9 Cobra R w/275/4017 since I bought it brand new. The inner/outer tie rods, rack and pinion, lower ball joints have all been replaced with no help. I am pulling out my hair trying to diagnosis this problem as it just started out of ther blue. Any suggestions would be very helpful.
tomustang
Psychotic Member
3,434
McLean Hospital
Mar 26, 2006
  • Mar 26, 2006
what springs?
Z
zebra23
  • Mar 26, 2006
steeda sport
tomustang
Psychotic Member
3,434
McLean Hospital
Mar 26, 2006
  • Mar 26, 2006
well, do you know for sure that the tire is rubbing the swaybar or is it a guess? unless you can see tire marks on the swaybar, sometimes rubbing occurs when the inner fenderwell trim has came loose and hangs also
some springs drop rates vary, even the same exact kind can be different, your steedas might have settled down more since it was new, especially with a wide tire like a 275 in the front
Z
zebra23
  • Mar 27, 2006
I see tire marks on the swaybar and I've had the springs in there for about 50k miles. I also had someone verify that it is rubbing by looking as I turned the wheel. My ride height has also not changed either.
Stangdriver1119
231
Saddle Brook, NJ
Mar 27, 2006
  • Mar 27, 2006
Is it only at full lock when you turn the wheel? Tire rub will always happen at full lock, especially on a lowered car with a wide tire having the front swaybar. There's nothing you can really do about it unless you go with a less wider tire or remove the front swaybar.
K
kstang69
153
atlanta, georgia
Mar 27, 2006
  • Mar 27, 2006
i just lowered mine with c springs and now there is a screeching sound only when i turn the wheel going real slow like a couple mph. something bent maybe from jacking? rubbing sway bar? loose bolt? anybody have any ideas?
Z
zebra23
  • Mar 27, 2006
Stangdriver, it happens at full lock. The thing is the rubbing occured only recently. I have been running this setup pretty much since I bought the car new. The rubbing is REALLY bad.
RAT
  • Mar 28, 2006
You're getting more sidewall flex from the front tires than in the past. Some brands of 275/40/17 tires are wider than others brands.
You could increase the PSI to help reduce the rubbing.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 4, 2006
#10
  • Jun 4, 2006
  • #10
im getting some rubbing on my swaybar on the passenger side at full lock
17X9 cobra wheels and a steeda sway bar
anything i should be worried about? should i just try not to go full lock on that side
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
